Do I need the 129 if I have the 61? | SatelliteGuys.US
VegasVoomer
672
45
Las Vegas
As it is now I have one dual lnb Dish pointing at 110/119 and a second single lnb dish pointing at 61. When I upgrade to the ViP622 do I really need the 129? What if anything will I be missing without the 129? There is an open slot in the dual lnb dish for a third one but is it really needed.
That's what I thought. I am seeing some channels on the 61.5 list that I havnt seen on the guide for my 811. NGEO, Starz, HGTV and Univ HD. I sub to everything.
When you upgrade to the 622 make sure you keep the 61.5 dish. Don't let them take it down... They are forcing the D1000 when you upgrade.
Suppose I were to buy a 622 from ebay. A new unopened one. Will they activate it? Then I wont even need anyone to come over and try to take down my 61.5 dish.
YES , if you own a 622 and you want to add it you can. I added two that way and did my own dish 1000 install. Today I also changed back to a dish 500 for 110/119 sats and a dish 500 for 61.5. I now get great strengths in the mid to high 90s on 61.5 and in the 100s on the main 110/119 sats. I was struggling with strengths that flucuated hourly on the 129sat due to it being a peice of crap. Now I get all my hd locals from Houston because they are on the 110 sat and I get the HD CBS from New York because I' m eligible, on 61.5 . I'm in southeast Texas about 90 miles from Houston. Dish tried to get me to upgrade to a dish 1000 when I called but I said no thanks Had one and went back to 61.5 and I couldn't be happier. I would keep the 61.5 dish if I was you.
Hey El Dorado Hills--
I live up the hill in Rescue. In a few days I want to upgrade to HD with the 211. Since I only own the Dish 500, they will install the 1000 for HD channels on 129. How is your reception from 129? With all its problems, I am hoping that we get better reception from our part of the country.
esteps
gbjbany said:
you'll only get those extra's when you go to a VIP receiver, 622, 211 etc.
Split DMA OTA EPG - fixed by software update?
Direct's H-20 to DIsh vip 622
