dn super-dish | SatelliteGuys.US
dn super-dish
coathanger
43
Can anyone tell me what sat i can hit? (if any ).This dish has 3 lnbf,one is a pro. Any help app.
The FSS satellite LNB you can use for any of the FTA satellites up there. The Superdish is a wee bit small and may only get the strong stuff up there
Another consideration is that the LNBs on the Superdishes are all stacked, which means that the transponders are all sent down as vertical, with the horizontal ones stacked in bandwidth above the vertical ones. This requires special attention when setting up the receiver (a receiver with blind scan capability is a real asset here)...
Someone asked pretty much the same question just last week.
Take a look at all the posts in this thread, and it just might answer 90% of your questions:
http://www.satelliteguys.us/free-air-fta-discussion/110023-what-do-i-have-what-can-i-get.html
Additionally, search on: superdish 121
A few more threads will pop up relating to that particular dish.
What sort of receiver are you thinking of using?
I'm sure we can get you pointed at something to whet your appetite for FTA.
Welcome to SatGuys and the FTA section.
Red Sox on Ku
How to Retract Actuator Inner Tube for Bud Dish?
