Dlp tv popping sound when turned on | SatelliteGuys.US
ozzy1028
203
Ok, I bought a samsung dlp tv back in october. Model hlt4675s samsung. HAve not had any complaints out of this set whatsoever until recently. About 2 weeks ago until the present when the set is turned on i hear a loud "popping" sound. At first i thought oh no, the bulb is getting ready to fail, but the lamp light on the front of the tv is not lit up to let me know that the lamp is bad. I have had no degradation of picture brightness and the tv works normally. The "popping" sound is almost like a speaker but i have the speaker volume all the way down on the tv since i use my external sound system for everything. Any advise would be greatly appreciated.
If you're sure the noise is coming from the set give Samsung a call and have them send a tech out. The set should still be under warranty.
NightRyder
How did it go with the servicing?
Thats the only problem with the DLP's its a TV with internal moving parts.:rolleyes:
Well, the samsung guy came out yesterday and wouldnt you know it, the past 2 weeks i have not heard the popping sound. The tech said it sounded to him like it may be the satellite signal. But i doubt it since i turn the tv set on before the dish box. Oh well, hopefully it doesnt do it any more.
Sony 5300 runs hot - Protection kicking in
Toslink Optical Audio Switcher
