oswald said:Hi folks,
I am moving soon and have a question about distant networks. Does Dish offer the distant networks (for those eligble to receive them) in HD or just in SD? Thanks for the answer in advance!
As much as I would like them in MPEG 2, I think this is wishful thinking. KCBS-DT is MPEG 4 (alright, "psuedo" MPEG4) on 129 and MPEG 2 on 148. WCBS-DT is still MPEG 2 on 61.5 but it seems any new offerings are going to be MPEG 4.lakebum431 said:Never know, CBS is still in MPEG 2.
I wasn't bringing up the whole down rez debate in my previous response to Lakebum - To clarify, by "pseudo" I meant that the 129 signal is MPEG2 that is "masked" as MPEG4. I agree with you that KCBS-DT on 129 was only viewable with MPEG4 capable receivers such as the 622. Never said WCBS-DT (and KCBS-DT on 148) was anything but MPEG 2.Kirby Baker said:There is no "psuedo" MPEG4. NY HD locals are 100% true-blooded MPEG-2 streams. The only thing is that CBS and NBC are down-rezzed to 1440x1080. From what others have said elsewhere, the LA HD locals are exactly the same. They simply have these channels set to be viewable only on MPEG4 receivers, but that has nothing to do with the channels actually being MPEG2 or 4.
BigFella said:As much as I would like them in MPEG 2, I think this is wishful thinking. KCBS-DT is MPEG 4 (alright, "psuedo" MPEG4) on 129 and MPEG 2 on 148. WCBS-DT is still MPEG 2 on 61.5 but it seems any new offerings are going to be MPEG 4.
Waltinvt - Do you think it might be June? I believe Charlie mentioned that month a chat or two ago.
waltinvt said:My personal opinion is I think Charlie is just too cheap and doesn't figure he can make any money with HD DNS but doesn't have enough guts to say so. He'd rather be vague and stall around until he can get enough HD LiLs up so that the whole DNS issue goes away.
Some (many) rural area subs will be basically screwed for a long time but he doesn't care if it's not enough to hurt him in the pocketbook.
Again, HD DNS won't be any more or less allowable after April 30th than they are now. The only possible influence it may have that I can see is maybe having the digital testing option makes it more likely that more afilliates will grant waivers, since they know if a test is done and it proves in favor of the viewer, the afilliate gets stuck with the testing charges.BigFella said:Since Dish is in business to make money, I guess I'll have to agree with your opinion. I'm holding out hope however that he's figuring he needs 30 days after the April 30 date to get the HD DNS ball rolling!![]()
BigFella said:Of course, if the "whole DNS issue goes away", then I'm SOL as far as distant HD is concerned because I can get local HD from Dish right now if I wanted to give up my distant SD nets.
Limited time offer
