dishpro adapter | SatelliteGuys.US
dishpro adapter
Not open for further replies.
B
brm
Guest
i have a superdish installed aimed at ----->110, 119 and 121, i noticed my legacy receiver wouldnt lock the signal. someone suggested dishpro adapter. will superdish with dp34 switch work with my 2700 and / or 3900 ird if i connect with dish proadapter?? where does the dishpro adapter connection goes in the circuit , if i buy the dishpro adapter from you guys, will you supply the schematic installation of the dishpro adapter?? thanks
The 4 digit receivers (Legacy receivers...2700, 5000, etc) will work with Superdish as long as you have the adapter on it. Unless your Install screen has 105 & 121 listed, you won't get those satellites. You will get 110 & 119.
The dishpro adapter goes right by the receiver..one line to the receiver, one to the switch.
Super Dish
Member theaters?
