DishNetwork Uplink Activity Report - 2/20/2008 11:51am - 134 changes | SatelliteGuys.US
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/23/2008 - 134 changes
Uplink Comparison Range: 02/20/2008 11:26A - 02/20/2008 11:51A -
211(3) - NOTAX [MPEG2 SD] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
257 - SPRKY (NA) removed from EchoStar5 129W TP 17 ConUS beam
258 - INFO (NA) removed from EchoStar5 129W TP 17 ConUS beam
259 - INFO9 (NA) removed from EchoStar5 129W TP 17 ConUS beam
298 - FREE (A) removed from EchoStar8 110W TP 02 ConUS beam
679 - PHNIN moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 15 ConUS beam (A)
689 - TTV moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 15 ConUS beam (A)
690 - CTV moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 15 ConUS beam (A)
692 - SLNK2 moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 16 ConUS beam (A)
693 - SKLNK moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 16 ConUS beam (A)
709 - SETI moved from EchoStar9 121W TP 05 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
710 - ICBLE moved from EchoStar9 121W TP 05 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
723 - ERASP moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
746 - ARYDI moved from EchoStar9 121W TP 06 ConUS beam to EchoStar9 121W TP 16 ConUS beam (A)
756 - RADIT moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
770 - NBN moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
771 - NORST moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
774 - NEWTV moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 18 ConUS beam (A)
793 - SETMX moved from EchoStar9 121W TP 18 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
797 - SHARA moved from EchoStar9 121W TP 18 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
798 - SAMAY moved from EchoStar9 121W TP 18 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
808 - B4UMU moved from EchoStar9 121W TP 25 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
813 - HT moved from EchoStar9 121W TP 16 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
5708 - CTS moved from EchoStar9 121W TP 10 ConUS beam to EchoStar9 121W TP 15 ConUS beam (A)
5716 - SETMX [MPEG2 SD] added to EchoStar9 121W TP 18 ConUS beam (Available)
5719 - K TV moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 18 ConUS beam (A)
5720 - GLOBO (A) removed from EchoStar9 121W TP 15 ConUS beam
5722 - SHARA [MPEG2 SD] added to EchoStar9 121W TP 18 ConUS beam (Available)
5724 - SAMAY [MPEG2 SD] added to EchoStar9 121W TP 18 ConUS beam (Available)
5725 - ALARA moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 29 ConUS beam (A)
5726 - IQRAA moved from EchoStar9 121W TP 26 ConUS beam to EchoStar9 121W TP 18 ConUS beam (A)
5727 - B4UMU [MPEG2 SD] added to EchoStar9 121W TP 21 ConUS beam (Available)
5730 - HT [MPEG2 SD] added to EchoStar9 121W TP 16 ConUS beam (Available)
5845 - SPRKY [MPEG2 SD] added to EchoStar5 129W TP 17 ConUS beam (Not Available)
5846 - INFO [MPEG2 SD] added to EchoStar5 129W TP 17 ConUS beam (Not Available)
5847 - INFO9 [TV] added to EchoStar5 129W TP 17 ConUS beam (Not Available)
5954 - MP444 [MPEG4 HD] added to EchoStar2 148W TP 10 ConUS beam (Not Available)
5959 - MP244 [MPEG4 SD] added to EchoStar2 148W TP 10 ConUS beam (Not Available)
5960 - XWJET moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
5961 - XWSEE moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
5965 - XWAOW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
5966 - XWSAW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7041 - WJET moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7042 - WSEE moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7043 - WICU moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7044 - WFXP moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7047 - WQLN moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7210 - WAOW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7211 - WSAW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7212 - WJFW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7213 - WFXS moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7216 - WHRM moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 09 ConUS beam (A)
7778 - WAPAD EchoStar10 110W TP 25 Spotbeam 49 mapdown of 27 added (A)
8279 - WTMO EchoStar10 110W TP 29 Spotbeam 01(FL) mapdown of 31 added (A)
8699 - WRMD [MPEG2 SD] added to EchoStar10 110W TP 29 Spotbeam 01(FL) (Not Available)
9223 - WWDT [MPEG2 SD] added to EchoStar10 110W TP 04 Spotbeam 01(FL) (Not Available)
9631 - BTV moved from EchoStar9 121W TP 25 ConUS beam to EchoStar9 121W TP 18 ConUS beam (A)
9905 - D121 moved from EchoStar9 121W TP 25 ConUS beam to EchoStar9 121W TP 21 ConUS beam (A)
15192 - KLUZ2 [EPG] added to EchoStar10 110W TP 27 Spotbeam 31 (Not Available)
15193 - WALB2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 03(FL,GA) (Not Available)
15194 - WMHT2 [EPG] added to EchoStar10 110W TP 04 Spotbeam 04(MA,VT,PA,NY) (Not Available)
15195 - WTEN3 [EPG] added to EchoStar10 110W TP 04 Spotbeam 04(MA,VT,PA,NY) (Not Available)
15196 - KAMR2 [EPG] added to EchoStar10 110W TP 26 Spotbeam 26 (Not Available)
15197 - WPCH2 [EPG] added to EchoStar10 110W TP 20 Spotbeam 06 (Not Available)
15198 - KLRU2 [EPG] added to EchoStar7 119W TP 07 Texas beam (Not Available)
15199 - WVLA2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 12(LA) (Not Available)
15200 - WKBW3 [EPG] added to EchoStar10 110W TP 27 Spotbeam 09 (Not Available)
15201 - WCFE3 [EPG] added to EchoStar10 110W TP 18 Spotbeam 04(MA,VT,PA,NY) (Not Available)
15202 - WSOC2 [EPG] added to EchoStar10 110W TP 26 Spotbeam 06 (Not Available)
15203 - WYCC3 [EPG] added to EchoStar10 110W TP 31 Spotbeam 19 (Not Available)
15204 - WAHU1 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15205 - WAHU2 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15206 - WHTJ1 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15207 - WHTJ3 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15208 - WVAW1 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15209 - KFXA2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 23(IA,WI) (Not Available)
15210 - KGAN2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 23(IA,WI) (Not Available)
15211 - KRWG3 [EPG] added to EchoStar10 110W TP 29 Spotbeam 31 (Not Available)
15212 - KVIA3 [EPG] added to EchoStar10 110W TP 29 Spotbeam 31 (Not Available)
15213 - WSEE2 [EPG] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
15214 - WEVV2 [EPG] added to EchoStar10 110W TP 25 Spotbeam 14(KY,IN) (Not Available)
15215 - KFSM2 [EPG] added to EchoStar10 110W TP 23 Spotbeam 20(OK,MO,AR) (Not Available)
15216 - WBAY3 [EPG] added to EchoStar10 110W TP 23 Spotbeam 23(IA,WI) (Not Available)
15217 - WGGS3 [EPG] added to EchoStar7 119W TP 05 Carolinas beam (Not Available)
15218 - WOGX2 [EPG] added to EchoStar10 110W TP 23 Spotbeam 03(FL,GA) (Not Available)
15219 - WCTX2 [EPG] added to EchoStar7 119W TP 03 Northeast beam (Not Available)
15220 - WUVN2 [EPG] added to EchoStar7 119W TP 03 Northeast beam (Not Available)
15221 - WUVN3 [EPG] added to EchoStar7 119W TP 03 Northeast beam (Not Available)
15222 - WMPN2 [EPG] added to EchoStar10 110W TP 26 Spotbeam 11(AL,MS) (Not Available)
15223 - WMPN3 [EPG] added to EchoStar10 110W TP 26 Spotbeam 11(AL,MS) (Not Available)
15224 - WJCT5 [EPG] added to EchoStar10 110W TP 23 Spotbeam 03(FL,GA) (Not Available)
15225 - WATM2 [EPG] added to EchoStar7 119W TP 01 Northeast beam (Not Available)
15226 - WATM3 [EPG] added to EchoStar7 119W TP 01 Northeast beam (Not Available)
15227 - WWCP2 [EPG] added to EchoStar7 119W TP 01 Northeast beam (Not Available)
15228 - KMBC2 [EPG] added to EchoStar10 110W TP 18 Spotbeam 24(KS,MN,IA,OH,NE) (Not Available)
15229 - KCET4 [EPG] added to EchoStar7 119W TP 03 South California beam (Not Available)
15230 - KOCE4 [EPG] added to EchoStar7 119W TP 01 South California beam (Not Available)
15231 - WKAR3 [EPG] added to EchoStar10 110W TP 20 Spotbeam 13(MI,IN,OH) (Not Available)
15232 - WKAR4 [EPG] added to EchoStar10 110W TP 20 Spotbeam 13(MI,IN,OH) (Not Available)
15233 - KGLA1 [EPG] added to EchoStar10 110W TP 23 Spotbeam 12(LA) (Not Available)
15234 - WLAE2 [EPG] added to EchoStar10 110W TP 23 Spotbeam 12(LA) (Not Available)
15235 - WLAE3 [EPG] added to EchoStar10 110W TP 23 Spotbeam 12(LA) (Not Available)
15236 - KXVO2 [EPG] added to EchoStar10 110W TP 20 Spotbeam 24(KS,MN,IA,OH,NE) (Not Available)
15237 - WSIU4 [EPG] added to EchoStar8 110W TP 05 ConUS beam (Not Available)
15238 - WFMZ2 [EPG] added to EchoStar10 110W TP 12 Spotbeam 04(MA,VT,PA,NY) (Not Available)
15239 - WFMZ3 [EPG] added to EchoStar10 110W TP 12 Spotbeam 04(MA,VT,PA,NY) (Not Available)
15240 - KAET4 [EPG] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
15241 - WPXI3 [EPG] added to EchoStar10 110W TP 29 Spotbeam 09 (Not Available)
15242 - KESQ2 [EPG] added to EchoStar10 110W TP 31 Spotbeam 39 (Not Available)
15243 - WLNE2 [EPG] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
15244 - WSBE2 [EPG] added to EchoStar3 61.5W TP 16 ConUS beam (Not Available)
15245 - KRXI2 [EPG] added to EchoStar7 119W TP 05 North California beam (Not Available)
15246 - WCVE1 [EPG] added to EchoStar10 110W TP 23 Spotbeam 05(NC,VA,SC,DC,MD) (Not Available)
15247 - WCVE3 [EPG] added to EchoStar10 110W TP 23 Spotbeam 05(NC,VA,SC,DC,MD) (Not Available)
15248 - KBTC4 [EPG] added to EchoStar7 119W TP 03 Northwest beam (Not Available)
15249 - KCPQ2 [EPG] added to EchoStar7 119W TP 03 Northwest beam (Not Available)
15250 - KIRO3 [EPG] added to EchoStar7 119W TP 03 Northwest beam (Not Available)
15251 - KCBU2 [EPG] added to EchoStar10 110W TP 26 Spotbeam 34(UT) (Not Available)
15252 - KSPS3 [EPG] added to EchoStar10 110W TP 18 Spotbeam 40(WA) (Not Available)
15253 - KWSU2 [EPG] added to EchoStar10 110W TP 18 Spotbeam 40(WA) (Not Available)
15254 - WUSI4 [EPG] added to EchoStar7 119W TP 05 Midwest beam (Not Available)
15255 - KJRH2 [EPG] added to EchoStar10 110W TP 04 Spotbeam 20(OK,MO,AR) (Not Available)
15256 - KNCT3 [EPG] added to EchoStar7 119W TP 05 Carolinas beam (Not Available)
19153 - ITVT1 [DATA] added to EchoStar1 148W TP 23 ConUS beam (Not Available)
Transponder Changes:
EchoStar2 148W TP 10 ConUS beam changed modulation scheme from 8PSK to QPSK
EchoStar2 148W TP 10 ConUS beam changed symbol rate from 21500 MSPS to 20000 MSPS
EchoStar2 148W TP 10 ConUS beam changed FEC from 2/3 to 5/6
EchoStar9 121W TP 01 ConUS beam QPSK removed from tables
EchoStar9 121W TP 05 ConUS beam QPSK removed from tables
EchoStar9 121W TP 06 ConUS beam QPSK removed from tables
EchoStar9 121W TP 10 ConUS beam QPSK removed from tables
EchoStar9 121W TP 25 ConUS beam QPSK removed from tables
EchoStar9 121W TP 26 ConUS beam QPSK removed from tables
EchoStar9 121W TP 30 ConUS beam QPSK removed from tables
Channels in the system: 4655
(A) = Available to subscribers
(NA) = Not Available
Looks as if sub-channel EPG info is back in the stream for a lot of DMAs, and at the same time Dish took down their internal channels that were on E*5 (edit: actually, looks like they just moved them to the 5xxx range). Also, someone must have a new satellite tax coming in.
also looks like they're gearing up for a channel renumbering they're clearing large blocks of numbers lately.
New groupings are overdue.
I bet they are going to number them the same as D so it is easier to convert over.
Its been stated no new HD today. They'll be coming "soon".
ROFL
D
DishNetwork Uplink Activity Report - 2/20/2008 5:10am - 20 changes
D
DishNetwork Uplink Activity Report - 2/20/2008 4:00pm - 1 change
