Dishnetwork super dish | SatelliteGuys.US
weslaco
10
Hello yall, first thanks for the support. Now my question. I got a 36" superdish from dishnetwork. Can it be used for fta stuff? What lnbs do I need? Can I get more than one satellite at one time?
you can use it for the normal FTA stuff (the linear stuff)
Use the LNB that is straght down the barrel (the mast).
Thanks Ice, for the info. I 've found it very useful in my conffusing road to fta.Now I also have a directv dish( 3 lnbs). Does it make a difference wheater I use my super dish from dishnetwork or can I use both? Is the lnbs compatable with fta? A far as trying to aim at more than one satellite at one time with one dish can it be possible? Thanks again man .
Thank You
Can I get these channels using FTA?
