DishNet 811 (HiDef receiver) | SatelliteGuys.US
Alex Galperin
2
Would anyone be able to tell me if the new Hi Definition receiver from DishNet can switch from Widescreen mode to Standard automatically . Thank you
No, you have to push the "*" button to choose between the modes. If you have the widescreen mode set on the sd channels and the normal mode set on the HD channels, the 811 and the 6000 will automatically switch between the two different settings when you change from sd to hd channels. There is one setting for sd and one for hd.
HD Package not worth it!
DVR 921? Where can I get one?
