DishMover Program - What if I have SuperDish plus 2nd 61.5 dish? | SatelliteGuys.US
smooth28la
294
Currently I have Superdish 121 (for international channels) with a second 61.5 dish connected with DP44 switch.
How much extra, if any, do I need to pay to utilize the DishMover program?
Is there another annual programming commitment?
The apt I'm moving to already has a Dish 500 set up from the previous tenants. Will that make any difference that the wirings are in but the Dish needs to be upgraded?
It would all depend on what kind of equipment you need when you get there. Yes, the existing D500 will need to be upgraded to a SD121, but what do you use off of 61.5? locals? HD? Whatever Dish quotes you for a price will include all of your services you currently have to be installed at your new location.
What that'll cost depends on Dish. The only real way to find out is to call.
Check Switch Screen
942 strech mode issues?
