Dishin' It Up actually ending April 30th ? | SatelliteGuys.US
kstuart
5,206
Northern California
Hello,
I was just wondering if upgrading to a 622 will actually cost more on May 1st, or is the "expires April 30th" phrase in the Dishin' It Up description just there to get people to do it sooner (because they will think the opportunity is going away)?
Hello,
I don't know about Dishin It Up but the ClubDISH cards always have an expiration but don't actually expire. I suspect Dishin It Up is the same.
Hello,
There has been dishinitup for several years now, it will continue. The pricing changes when the promo changes. So after this dishinitup, a new one will come out with different prices.
Any likelihood that:
- That the terms will be worse (less of a discount)
and/or
- That the new promotion will be later than May 1st (i.e. a gap between the two) ??
Look deeply into your cat's eyes. You will see all you need to know of the future. Soon, you will be feeding the cat. Then, you will be emptying the litter box.
That's all you need to know.....
Usually the deals either stay the same or get better. I wouldn't stress about the date. Just do it when you are ready.
Well put. Although the latest change was half good half bad. The 622 is definitely cheaper for some. Though the prices are the same after credits, you know have to get a 50 credit through sending in a form when before it was given. BS. They know that people will not send it in or they will deny many of them.
721 - Skip This Timer 1 Time
OTA loss with 4.03
