dish500 for 105 and 121 or other combinations? | SatelliteGuys.US
hobojoe
492
so caif usa
:confused: can a dish500 be used to get 105 and 121 a difference of 14deg? or any of the fallowing; 105+119=14deg/110+121=11deg/119+129=10deg/121+129=8deg? dish500 was designed for 110 and 119 a 9deg difference. i would think a couple deg wouldn't matter. any one try any of these combinations? thanks!
105 & 121 are FSS satellites so you need a 30" dish
options you can use for Dish
110/119
119/129
129/148 If you add a LNB :)
One Dish HD Solution??
my hd upgrade experiance so far.
