Dish1000 question, what type of LNB's? | SatelliteGuys.US
shingles
6
I am wondering what type of LNB's should be on the Dish1000? The twin (bigger one) should be a DPP or just a DP?
would using the wrong LNB cause a problem?
thanks,
-S
also the DP twin doenst have the 3rd input connection that the DPP lnb does, so you would have to use a switch of somesort to connect to get 110, 119 and 129.
LNB problem or Receiver problem
OTA guide info on 622
