Dish1000 plus and DVR625 receiver connection | SatelliteGuys.US
tim995785
TN
Anyone knows is it ok to use the DVR625 receiver with the DP44 switch power supply? I have the following setup and I am connecting it first time and don't want to damage the receiver or LMBs by supplying too much power.
Do these LMBs get the power from the receiver or I have to use the DP44 switch power supply?
Dish 1000plus which includes 110,119,118.7&129 all on one dish
DP44 Switch (out side the house)
DP44 switch power supply (inside the house)
For the 1000plus dish to work you will need the 44switch and the power supply so the dish and the LNB's get the correct power to work correctly and so the receiver works correctly.
Receiver corrupt
downgraded but my dish bill is still the same!
