Dish UHF Remote Address Change | SatelliteGuys.US
C1787GJ
251
MASSACHUSETTS
Ok so somehow my 522 and my 625 reciever last night ended up with the same UHF remote address for tuner 2. I can't remember how to change it though. Can someone please lend me some expertise (spelling) :) on this matter. Thank you!!!!! If it makes a difference I would like to change the one on the 625.
get the system info screen up on the one you want to change
-on remote, press and hold satellite button until all 4 light up and the sat button blinks
-hit number for new code
-hit # button...remote will blink 3 times
-hit record button to tell receiver this is the new address
to be on the safe side you may want to disconect your antenna on the rec you dont want to change the address on. just to be on the safe side
Thank you very much sir worked perfectly!!! Any idea how that would get changed by itself, I know no one here knows how to do it unless it was accidently done, but thats a lot of steps to accidently get changed. Thanks again!!! :D :)
Vip211 info / screen shots.
Signal lost but other tvs work?? help
