Dish TV 625 | SatelliteGuys.US
Dish TV 625
LloydRob
4
I just upgraded from a dual feed receiver to the 625 DVR Dual feed receiver. I also have an 811 receiver in another room. From a post at another forum with the same situation, the user states "I really like the Dish DVR with it's second output and dual tuners. I can feed the second output (as well as the first) back to the house wiring and watch recorded shows on any TV, as well as record from any using the uhf remote."
How do I feed back to the house wiring to watch recorded shows on the tv with the 811 receiver?
I'm not up on the 811. How is it connected to the TV? If it's connected using the composite or S-video, maybe you can use the house cable (ch 3 & 73, or uhf 61) and feed that into the RF input and use the TV/input remote button to switch between the 811 output and the 625.
I was assuming you had a separate cable not sharing Sat signal. If your already feeding the TV2 signal with the Sat signal then you need a special splitter that handles that. I think it's called a diplexer.
Dish DVR 942
Islanders game blacked out!
