Dish Size | SatelliteGuys.US
Dish Size
davies_z
30
Can I use a 60cm dish with a Fortec receiver to receive signals from Euelsat W4,PAS 17, and Intelsat 907 from Nigeria?Please also recomend an Adequate size dish for my area.
Eutelsat W4 - Yes.
PAS 17 - Do you mean PAS 7? Nothing on PAS 7 is transmitted to Nigeria. Or do you mean PAS 10? It should work.
Intelsat 907 - Yes, but everthing is encrpyted that is transmitted to Nigeria.
What size dish? A 2.4 meter or more c-band dish would be more useful.
Sorry I meant PAS 10. Thanks. What of NSS7? Can a 60cm dish work to get signals from it?
The West Africa spot beam on NSS 7 looks pretty strong. A 60cm dish should work.
lnb question
ini file downloader
