Dish Serial Port Commands | SatelliteGuys.US
lshanepowers
2
I did a search and couldn't find anything. I have a DISH 508 receiver. It has a serial port on the back. Is there a command list somewhere of how it can be controlled via RS232? I've got a home automation system that I'd like to tie this into.
Thanks,
-Shane
That's a 50 pin connector. Serial Ports (RS232) are either 9 or 25 pin. There might have been some 15 pin in the past also.
You're right, it is a 50 pin. I was thinking it was a 25 pin serial port. I'm out of town on vacation so I didn't check it right before I posted.
-Shane
why do I only get odd transponders
To ask or not ask is the question! Voom related
