Dish Receiver - Internet Connection Sharing | SatelliteGuys.US
BriOz84
I have looked everywhere to try and figure out this problem but I have found nothing that has helped. I hoping this forum could help provide the best solution. I have a Dish VIP 622DVR receiver that is located in a media closet with a laptop (wireless internet connection), DVD, receiver, etc... There is no hard internet connection in the closet and I only use a cell phone; however I have a wireless router in another room of the house. I want to hook up my Dish receiver to a broadband connection but don't want to run a wire, get a landline, or buy a Homeplug. The laptop is my old Sony Vaio that runs on XP. I found that there is a way to share an internet connection...i.e. connect an Ethernet cord from my computer directly into the Dish receiver and share the wireless connection. I configured my computer to allow for this connection; however my receiver is still unable to connect. Thoughts, ideas, suggestions??? Thank you.
What kind of cable are you using
A standard CAT 5 Cable doesn't suffice for something like this. You will need a crossover cable. I had a similar set up a few months ago with my PS3 and it turned out the only problem was that I needed a crossover cable. Once I got that I was able to share internet with almost anything turning my laptop into a wireless hub of sorts.
Get a Crossover cable, and make sure it's a crossover cable, or you could try to make one yourself if that is your sort of thing, but I would just recommend you go get a crossover cable and see if that doesn't do the trick.
PIP questions
Calvary CAUO37500 External HDD
