Dish Questions | SatelliteGuys.US
Dish Questions
winterdude
2
OK. I currently have Cable and I'm looking at possibly getting Dish because I can combine it with my phone company. So I have some questions.
Do you need a satellite box for each TV? If so must you pay per box you have?
Does it really go out everytime bad weather hits?
Are you commited to keeping the service or can you cancel any time without any fees?
Welcome to Satelliteguys.
You do not need a receiver for every TV. There are dual tuner receivers available:
322 (SD no DVR), 625 (SDDVR), and the 622 (HDDVR). The firstbox is included in the programmin fee, there is a charge for each receiver after that. For the DVRs there is also a DVR fee unless you sub to the Everything pack, then it is waived. With dual tuner receivers, they must be hooked into an active phone line or there is a charge for the second tuner (kind of like an additional receiver charge).
The weather has to be really bad or the dish not aligned properly for the signal to go out. In 9 years, I have lost my signal maybe 5 times. It comes back once the weather lightens up.
Whether or not there is a commitment depends on the plan you sign up for. Since you are combining with the telco, call them up and see what your options are.
Scott
Planning to get Dish Network
LIL Markets still not on Dish
