dish question????? | SatelliteGuys.US
dish question?????
unclesalty
16
can I take a 500 dish, with a dish pro twin head and run 1 output from it to the eastern arc 1000.4 wing dish input? I have a 1000.4 hitting 72 77 and 61.5 now and I want to put the 500 dish hitting the 110 119 into the extra port, will that work? And if that wont work am I better off with 119 or 110 as the wingdish and what lnb do i need to use for it? thank you in advance.
better to just use a dp dual. but i dont know what diffrence it will make, i dont really see what extra channels you would gain.
Why is dish still missing games in HD?
6.4 remote for 222k
