dish pro plus switches | SatelliteGuys.US
all4jo
398
12
Haiti and lexington ky
hey guys i have 4 antennas here in haiti and my sw64 switch is starting to give me problems. Do you guys think i could use a dpp33 or dpp44 switch instead? i have 3 622 receivers and i figure i could use the separators so that i only use 3 lines.
also i have legacy lnbs. would i need to replace the lnb's? also would i only need to get single lnbs?
You will need to replace the lnbs. YOu can only use DP lnbs with the DPP switches.
Thanks for your quick response. also do you know if there is such a thing as a dish pro plus 33?
i ask this because i just need a hook up for 3 satellites and the price of the 44 is very expensive.
HD locals in Rockford, IL
Speed HD - just a whine...
