dish-pro-plus lmb | SatelliteGuys.US
dish-pro-plus lmb
cheito
85
usa
i amd trying to install a dish 722 HD dual tuner my question is i have a two dish 500 one poiting at 119,110 and the other at 129 for hd i need to know the set up with this lnb i have three outputs two on one side which i think i can hook up one for each one for the 119,110 for each tuner and the lonly one on the other side for 129 RIGHT ???? and is this reciver compatible with this lnb thats dish-pro tehcnology thanks.
the dpp twin lnb has 2 outputs and one input.
the output of you 129 dish has to connect to the input on the dpp twin lnb on you 110/119 dish.
does you 129 dish 500 have a single lnb or a twin lnb (the fat one with 2 eyes)?
question on PI channels
My Install guy is here!!!
