Dish Pro Multiswitches | SatelliteGuys.US
HippyPimp
2
Please Help!
I've been trying to find out if there is any way to split DP or DPP twin lnb's to 4 or more receivers. All I have found so far are the DP 34 or DP44 (DPP). Is there any other way? Buying a DP quad lnb is almost cheaper than either of these options. This doesn't make sense to me. I've asked this question on other boards, but can't seem to get a response. Please, someone help!
Thanks Iceberg. I found a DP quad nearby for a good price. Works great. If I need to upgrade in the future, I can use any 4X8 though, right? I'm sure the Dish switches are great, but they just seem so expensive!
Nope you have to use DP switches with DP LNB's. DP34's are cheap if you look around some
DISH works with DISH Directv works with Directv don't try interchanging them in most cases you will be disappointed.:mad:
one of the previous gold sponsers use to carry a knock off version that worked .. it was under 50 bux if I remember correctly.. I got one from their ebay store for like 11 dollars..
No Sound on one OTA
No Signal
