Does anyone know if a hookup using the old Dish Pro Dual LNB (as opposed to a DP Plus)..utilizing a DP 44 for a 129 Wing Dish...is a suitable installation for HD? Receiver is a 722...
If I read what you're asking
a DP Twin on 110/119
a DP single or dual for 129
using a DPP44+ switch
yes that will work
2 lines from the DPTwin to the 44+
1 line from the 129 dish to the 44+
also any LNB can be used for HD...When I had dish I used an old Legacy Twin on a D500, a Directv LNB (the old single ones) on a 36" dish and a SW21 to the 211k. Worked fine
Yes, that is the question...so the old Dish Pro dual is good then for use on HD with a wing dish wired into the switch....Thank You !!! My neighbor is set up that way and he is having mucho trouble with a new 722k...worked fine on his 211
it is the new type separator.....I'll check that. He does not need that switch anymore anyway...I might just swap out his LNB and pull that switch...I have a couple of DPP duals around somewheres....THANKS
There is no such thing as a DPP DUAL DPP only a TWIN or a separate switch. Dual LNBs are either LEGACY OR DISH PRO using the wrong terminology makes it hard to answer questions.
Yes, I have a 1000+ dish, with 2 DishPro lnbs and the one DPP 119/118 lnb each lnb is connected to a DPP44 switch to my HD receivers.
Limited time offer
