DISH Pro 500 receive 61.5 | SatelliteGuys.US
tony2tall
27
Can a DISH Pro 500 be aimed to receive 61.5? :cool: Correctly done I need a DISH 300 Pro Dual LNB, right? :confused:
What I lying around extra is the DISH Pro 500.
As per my PM to you (why PM then post, eh?), the Twin will work, but is futzy. As Bryan confirms, a Single/Dual will be better, and even better is to swap the "Y" arm for an "I" arm.
So can you have a DP Twin getting 119/110 and, though overkill for the job, another DP Twin getting 61.5? Can both outputs be used to run through 2 DP21 switches (guessing no)?
If you use a dish 500 for 61.5 or 148 just remember to set the skew to 90 (no skew).
Satellites Unlimited: Argh!!!
OTA Antennas
