dish ota with voom winegard antenna | SatelliteGuys.US
JJSerrano
20
I just moved and decided to get Dish over Voom. I still have the Winegard Sensor II antenna from Voom and was wondering what type of power supply I will need to use it with the 811.
"Switch has 12-volt DC receptacle, built-in two-way splitter for second TV outlet, a convenient power-on / off indicator light and cable TV input "
did you get tehj white switch with it?? if so sounds like it has an input for a 12v DC power supply. Put the power supply as close to your dish box as is practical and try it out. You can get a 12v DC power suplly at radio shack. The center pin on the power cord is almost always positive.....
Jon
so .....
did it just connect with rg-6 to the ant in on the voom box and thats it? the voom motorola box sent power to it and it worked great??
also you have three antenna in your link which one do you have??
It is the gs-2200 and it went through a diplexor with the sat signal. If it does not have the motorola diplexor on the voom box then it does not pick up a signal. I was wonering if there is something I could buy at Radioshack to replace that.
cable question
522 or Guide Glitch
