Dish not trackin the arc | SatelliteGuys.US
Techfizzle
Banned
985
i ran all new wires to the dish today, the old wires were not made to be outside.
Anyway, the dish moves.
The pole is dead-on level.
The dish was from a college, so it would of been installed by a profesional, so the elevation should be good
the dish it self can be moved by the motor, the motor sits on a mount, which rotates on the pole.
so if i rotate the mount to the south, i pick up some of the arc, if i rotate the mount 10 degrees west, i pick up some of the arc, but no matter how the mount is rotated, i cannot get all of the arc.
that 6 footer from sadoun is looking better
Here ya there fizzle!
A 6 foot sadoun dish is going to find a place here as well! What size is that one your trying?
K E V I N
the current dish is a 10 foot mesh perfect 10 on a h to h im thinking something in the mount is bent
will the fortec dish be able to receiver most c band digital channels?
That is what I was thinking that something is outta Wack!
From what Ice has said, yes it will pick up most that is up there!
Read this thread.
Bang around on that perfect 10 a little, if it is usable you will get it to work on something! :D
K E V I N
interface cable, help me, a friend of mine
Help me ID this dish
