Dish Logo | SatelliteGuys.US
Dish Logo
ralfyguy
3,242
437
McAlester, Oklahoma
On my 625, when it is turned off, it will show a dish logo and it says "Press Select To Continue" But it only shows up on TV2, and not on TV1 when in coax mode. There's only a distorted screen on TV1. I ran a channel scan on the TV, but it doesn't get better. If I press select to turn the receiver back on, I get my picture as normal.I hooked the TV1 up to adifferent TV with the same result. If the TV is in S-Video mode it shows up on both, TV1 and TV2. It also doesn't make difference if the receiver is set to channel 3 or 4.
Is the receiver broke?
This happens on all the dual tuners as far as I know, I'll tell you why too :)
It's so that the cable/OTA passthrough (CATV coax input on back of your receiver) works :)
I couldn't figure out why it did that until now :D lol
OotLink man you're right! Of course that antenna/cable passthrough couldn't work with a damn dish logo in the picture. Sometime you can't see the woods from the trees.
pole mount question
EchoStar Sub Growth Fattens Q3 Profit
