Do we have information on the LNB that can pick up both of these satellites on the same dish? I am hearing that the Invacom QPH-031 will pick them up, but I can not figure out if this is dishpro compatible or legacy compatible.
Dish-Direc said:Do we have information on the LNB that can pick up both of these satellites on the same dish? I am hearing that the Invacom QPH-031 will pick them up, but I can not figure out if this is dishpro compatible or legacy compatible.
goaliebob99 said:As of right now we dont.. The Inivacom LNB wont work as the signals on the FSS Side is Circular instead of linuear. (im hearing this from John H and P smith)
Iceberg said:P Smith
I scanned 118.7 with my Invacom quad on the linear side (10750) and got transponders but really low quality (60 on the Coolsat...63 is stable picture)
The above picture is the only free item on there![]()
photoman76 said:Here are some Broadlogic Spectrum Analyzer plots. Two are using a circular dbs lnbf at 119 degrees. It shows both Echostar 7 and part of AMC 16. The four signals on the left are on AMC 16. The others are on Echostar 7. The rest of AMC 16 is cut off because the dbs lnbf can't tune any lower. The third plot is of AMC 16 with a linear lnbf. It looks like crap because the circular signals overlap one another when using a linear lnbf.
check this http://dbstalk.com/showpost.php?p=589831&postcount=72photoman76 said:Here are some Broadlogic Spectrum Analyzer plots. Two are using a circular dbs lnbf at 119 degrees. It shows both Echostar 7 and part of AMC 16. The four signals on the left are on AMC 16. The others are on Echostar 7. The rest of AMC 16 is cut off because the dbs lnbf can't tune any lower. The third plot is of AMC 16 with a linear lnbf. It looks like crap because the circular signals overlap one another when using a linear lnbf.
umm...I don't believe testing *cough*hacking*cough* is tolerated here...AlbertaBeef said:Yes, I have an STB for testing. And yes, there's lots to watch with a DS2076. . .
Limited time offer
