Dish Liquidating 25,000 40" HDTV's $699 | SatelliteGuys.US
Mark_AR
1,448
North Arkansas
Just saw this commercial on G4-Tech-TV.
Dish is liquidating 25,000 40" Rear Projection HDTV's with universal remote (for their loyal customers)
They are offering them at $699.00 + $100 S&H (A 1,599.00 value)
1-866-436-9498
Hmm....
Might be ok for a low budget intro to HD.
I don't believe the 40" TV's are worth the $699, maybe $499 but not $699.
The 32" Tube Sets however are worth the $699 and are actually decent little TV's.
With the 921 bundle, it works out to $450 for the TV. Are these sets functionally comparable, except for one being a DLP RPTV and the other a direct view? Why don't you like the DLP? Conversely, why do you like the direct view set? Thanks for your insight. It's tough to make a decision on something sight unseen.
Stever1....I told you a few days ago that the 40" is NOT a DLP! Where did you hear this?
I Believe The 40" Is A Rear Proj. "CRT" Beast. If So The HD Should Be GREAT But The SD Channels Will Be Real BAD!
I just got the 34" for $499 - a special Dish ran in Denver last weekend.
It's not a bad set but the geometry is really off.
Hopefully getting it calibrated will fix it.
The 40" TV is a RCA CRT Rear Projection! At $699 in my opinion it's not that bad a deal, but do consider there is probably a lot better TV set out there for just a little more! Also consider that it is only 40" and the base is not that tall! But overall it might not be that bad a deal for a secondary HD TV!
izod said:
Any idea what they'll be replacing the 40" line with?
On the Tech Chat/Forum they talked about LCD flatscreens. Check out the Tech Chat/Forum summary thread for specific details of sizes and prices.
The sighting of the deal is the first post.
You can call 1-866-436-9498 for more info.
Also, welcome to SatelliteGuys. Hope you enjoy your stay :)
Granted this isn't the best deal out there.
Granted this isn't the BEST HDTV out there.
It was something I saw on a commercial. I reversed my DVR and kept playing it back as I typed in the info.
For someone wanting an entry (I said entry) level HDTV Rear projection set, this may be an option.
Considering I gave $2,149.00 for my Hitachi 57" a year ago, this $699 isn't going to break the budget of average joe american. The WAF isn't going to be a problem either. It would be on a $2000+ set.
I just think that Dish jumped the gun on HDTV. Market says that only 15% of all american households have HD. IT hasn't quite caught on yet. I give it 2 to 3 years and it will catch up and hit critical mass.
By then, the DVR's will be up to par and make a great HT experience.
If I am going to spend this kind of money on it then I might as well spend just a touch more since the better HD with a bigger screen is within reach of that price. I seen Wal-Mart Have a Philips Projection 51+" HD tv for $992 advertised a little while back.
522 or 510?
811 and lack ofguide info
