Limit is 6 receivers if all 6 are dual tuners that would be 12 tuners of which only 4 can be leased but the rest can be owned if your pockets are deep enough.
The 4 leased limit has been waived for some, if you are of good standing, sounds like you are, the ceo@echostar.com would be worth a try.
zero327, not sure what you are saying about "you dont want to be that CSR", can you clarify.
However to be clear, i suggested using the ceo@echostar.com address, i wouldnt use a csr.
You will not be permitted to keep more than 4 leased activated, mistake or not.
That is too funny! What exactly are they going to do shut them off?
I don't believe that at all. They are going to piss off a customer by shutting off a reciever that they already installed and the person is paying for. That would be the dumbest thing I have ever heard.
You claim that it happens all the time, but I have NEVER read about it happening here. If it was as common as you claim then I am positive that we would have heard about it. I would love to hear from someone that has had a receiver pulled because of a limit.
Limited time offer
