While I'm not exactly sure what you are using from your description, I can say that DVI does not have any audio signal. So, if you are connecting to a DVI port on one of the pieces of equipment, then no audio will be transmitted by that connection.it is a hdmi to dvi with another adapter to make it hdmi to hdmi
The DVI standard does not support audio. "Digital Video Interface".What the OP is talking about is the dish supplied HDMI to DVI cable, they also supply a DVI to HDMI adapter. Thus making it a HDMI to HDMI cable. I know for a fact (and it has been discussed here before) that it will pass Dolby 2.0 audio over this cable. What I don't know is if it will now pass 5.1 audio as well.
With what receiver does Dish provide an HDMI to DVI cable?
HDMI cables support audio.
622's used to pass Dolby 2.0 audio to the HDMI jack and then they upgraded the software to pass Dolby 5.1 audio to the HDMI jack.
That change has nothing to do with the cable.
Here is what you might be talking about.
Suppose a TV set has a DVI connector and a Digital audio input.
You can buy an adapter that connects the DVI connector and the digital audio input to an HDMI jack. That then allows you to use a regular HDMI cable to connect to a 622.
But I can't even find such an adapter at monoprice.com, so I think that installers probably simply used cables with DVI on one end and HDMI on the other to hook up 622's to TV's with DVI, or used HDMI cables and a DVI-HDMI adapter. Either way, a separate digital audio cable would be required.
This cannot be true, because a DVI jack has no audio connections. So, this HDMI<->DVI<->HDMI connection cannot have audio.The cable that I'm talking about has HDMI on 1 side and a DVI connection on the other side (this can be plugged directly into a DVI device and works for video only). The adapter has the opposite DVI side and a HDMI side on the other side. When you take the two together it becomes HDMI connections on both sides of the cable. When this is plugged in to the HDMI port on the 622 and a HDMI input on the other it will pass video and 2 channel audio for sure. No separate audio cable necessary
James Long said:P Smith was right ... "DVI signaling support only video, not audio." But thanks to the handshake between the receiver and the TV DVI signaling isn't used, HDMI signalling is.
Limited time offer
