dfergie said:NP...actually thank BFG he put it together...
Bradtothebone said:Thanks, BFG!
One minor correction on existing HD LIL Markets:
"Markets listed in order of size
Available:
New York, NY - 61.5
Los Angeles, CA - 129
Chicago, IL - 129
Philadelphia, PA - 61.5
Boston, MA/Manchester, NH - 61.5
Washington, DC - 61.5
Atlanta, GA - 129
Minneapolis/St. Paul, MN - 129
Denver, CO - 129
Nashville, TN - 129
Salt Lake City, UT - 129
Albuquerque-Santa Fe, NM - 129
Kansas City, MO - 129"
The list is correct in order of market size down to Nashville (30). Then it should read:
Kansas City (31)
Salt Lake City (36)
Albuquerque/Santa Fe (47)
No big deal - just striving for accuracy!![]()
Brad
Paradox-SJ said:I find it extreamly distastfull how the 6 largest DMA was skipped over in the first round for those other po-dunk towns. It speaks volumes...
stuart628 said:just a question, it says others planned for 110 after the HD locals, and it has cleveland/akron/canton-does that mean my hd locals are going on the 110? if that is the case, that is amazing, I wont have to upgrade to a dish 1000 yet!
garys said:One has to realize that not only does E* need transmission consent (if you look at the markets that are already up - why do some have the four major networks up in sd but not HD?) There is also the process of getting the signal from the dma. Not every market transmits in the same way, there is a lot of work needed to be done on the side of the dma as well as from E*. Plus, E* need to make room on their birds.
Slamminc11 said:From these two posts, who do you think knows more about how the process actually works? Thanks garys!
Limited time offer
