Dish for Starchoice and Bev | SatelliteGuys.US
newbiebell
5
Hi
I'm a subscriber to both Starchoice and Expressvu. In July I'm moving to a new house and my wife don't want 2 dish anymore on the house. Can I use a T90 toroidal to received both Starchoice HD and BEV HD???
I subscribed to both because Bev has Channels in HD that Starchoice doesn't have and the quality of Starchoice is better in my opinion.
does Using another dish void my subscribtion???
any solutions???
thanks
no a different dish doesnt void the subscription
Yes you can use a T90 for both Bell & Starchoice. I use to have a T90 for Starchoice and Dish Network
The LNB's for Bell though use reverse polarity (special LNB's). The Starchoice receiver will use regular linear LNB's
how many/what models of receivers do you have?
Hi
thanks for the info.
For Starchoice I have an old 401 receiver and dsr505 for HD.
For Expressvu I have 9242 hd pvr and 2 3100 receivers.
Can i use the lnb on bell and starchoice dish with the t90??
thanks again
no to both...you would need separate LNB's because the spacing is different
for the SC setup, you would need 2 dual LNB's and a 4x4 multiswitch
for the EVu setup, you run into an issue....because you need 4 inputs (and they dont make a reverse DishPro LNB) you would need 2 reverse duals, 2 3x4 multiswitches and 4 SW21 switches...kinda cumbersome
ok
thank you for the info.
for evu, could you tell me exactly the wiring diagram with 2 lnb, the multiswitch and the sw21, I think I will try this setup for both SC and Evu.
thanks again
Help getting Canadian tv in the states
Bell Expressvu
