Dish Finder Power Supply | SatelliteGuys.US
bohack
15
Pa
I just purchased a dish finder / pointer ($14 type) and noticed that a lot of them come with a power supply. The power supply consist of two 9 volts and a slip on F-connector. So the question is: How can I make one of those? I'm guessing it's two 9-volts wired in series to make 18 volts and then the F connector is wired with the tip being the positive and the ring being wired with ground/negative?
I guess your talking about the finder with an analog needle that read's the rf signal? If so that will work, but you will only be finding the Horizontal tp's @ 18volts. Hope this helps.
That just validated what I thought! Awesome I'm learning! Thanx
NBC - 105 NBC - 72 ?
Whats your favourite currently playing MeTV show?
