Dish Error Message | SatelliteGuys.US
Dish Error Message
wdavis9
73
13
meridian, ms
Let's try this again. Has anyone else got this message on a Wally.
Did it really need a new thread?
Someone else just had the same problem and posted a new thread about it. That thread provides a little more detail about exactly what the issue is:
I have two Wally receivers that are both failing. One is about 3 years old, the other just over a year. For antennas, I have a King Tailgater Pro on my work setup, at home is a Winegard Trav'ler.
I have a dialog box pop-up (1604) saying to call Dish, there is a problem that could affect viewing experience. I called and they said the memory was failing.
I checked status in the diagnostics menu. Sure enough, it showed NAND Status failing. Seems odd both receivers are doing the same thing. About once an hour the screen goes blank for 5 seconds or so and pops back on.
Wally Receivers Failing
OTA adapter causing problems with Hopper Duo
