Dish Elevation Angle | SatelliteGuys.US
kirky27
6
Hey Guys,
I have a question. I'm in South Florida and trying to set up my motorized system. My coordinates are:
Latitude 25 33' 39'' North
Longitude 80 21' 14'' West
My equipment:
76 cm Winegard (DS-2076)
Invacom Quad QPH-031 LNBF
Moteck SG2100 motor
Coolsat 6000
Chieta 4x1 DiSEqc Switch
What angle do I set the dish to? Some manuals say 40 degrees minus the declination and some say 30 degrees minus the declination.
What accounts for the differing settings and which is the correct setting for my location. If I try the 40 minus declination then the bolt/nut at the rear of the dish prevents the further movement to achieve that angle.
For my location the declination = 4.23 degrees
Thanks.
Motor should be at an elevation of 65º
Dish elevation should be at 26º
Use the RED line when setting elevation on the dish (see below)
Watch out if its a genuine SG2100 one side of the motor is marked for ELEVATION and the other LATITUDE.
Thanks for the prompt response. I have the genuine SG2100. The two different scales are on the different sides. But can you tell me why some manuals say 40- declination and some say 30 - declination? I am really curious as to why. And If you also have the winegard could you please post a pic of how you set it up to achieve that anle of 38 degrees. I understand that my dish angle should be 26 but I am really interested to see how you set yours up to get 38 deg.
Kirk
I mean the SG2100 downloadable manuals some say 40 - declination and some say 30 - declination. I am confused why the same manufacturer would have different instructions. the picture that would help me is one that shows how the dish is attached to the sg2100 pole.
Thanks for your help
Kirk
Thank you Pete for your patience but if you check the link that you gave me just now in your last reply the manual states the dish angle should be 40 - declination. Yet you say the dish angle should be 30 - declination.
I am asking why is there a difference in the instructions.
Kirk
I have the SG-2100 (DMSI), and the dish elevation is 30 - declination. Manuals for most FTA equipment are about as useful as a match in hell ;)
I think the newer motors use 30-
but older ones used 40- or something. If your motor came with a manual, the manual that came in the box is probably the most right one.
I used to have the same confusion on the 40 and 30 degree thing before installing my SG2100.
However, I remember reading somewhere then that the very original SG2100 mount has "40 degree minus the declination" setting, whereas the recent/redesigned SG2100 has "40 degree minus the declination" setting.
So, nowaday, we should all concern about the "40 degree minus the declination" setting.
Hope this helps!
I'm terribly sorry!!
I mean 30 as in follows
However, I remember reading somewhere then that the very original SG2100 mount has "40 degree minus the declination" setting, whereas the recent/redesigned SG2100 has "30 degree minus the declination" setting.
So, nowaday, we should all concern about the "30 degree minus the declination" setting.
channel Master 1.2m motorizing?
newbie racking my brain
