Dish DVR 510 Software Update | SatelliteGuys.US
res0zvle
2
texas
Dish DVR 510 Software Update Problem
Just bought a used Dish DVR 510 and the problem is that the software on it is too old and couldn't pick up satellite 110. Dish says that the receiver is now too old and cannot be updated. They teold me to throw it out. Is there any way to update the DVR's software. Thanks
Jim
The receiver should still work. Turn it off and leave in standby mode like boba said for a few hours and then turn it back on to check the software version. Press Menu twice to check what version you have. The receiver needs to be connected to 119.
I think your CSR needs to go pee in a bottle. I got a 508 many years ago and it has always seen 110. Do you have any other receivers in your setup? Sounds like a LNB/Switch issue.
Practically all sats spooling FW ( exclude 721/921 FW what reside on 119 W exclusively );
the issue could be with the 'home' tpn signal level.
Rule of thumb - the tpn number is 19, some of sat have different number for the home tpn - search here for full list.
No HD: Sharks vs. Flames
Comedy Central HD Launches! (not on Dish!)
