Dish Anywhere Question... | SatelliteGuys.US
D. Manley
410
59
United States
I know from past experience that channel changes, additions, etc., do not populate immediately on the mobile app but I can't remember how long it takes. Anyone know how long and while asking, if the Mobile app is viewing the HWS, why is there any difference in the guides at all?
Sent from my DROID RAZR using Tapatalk
The online guide is built off the Hopper guide if the Hopper is IP connected. I believe they should populate immediately. I would try shutting down the app and relaunching.
Thanks, but that doesn't do it nor does, an uninstall/reinstall. I remember when ESPNU went HD it took several days to show up in the app but I don't remember precisely how long. I really can't imagine why this is as it is - as you said, you'd think it would mirror the HWS but apparently, something else factors in.
Just for kicks, check & see if LHN (channel 407) shows up in your app. Sorry - only new channel I can think of.
Just checked, didn't see LHN 407. Android Dish anywhere
That's what I thought - takes a few days for changes to populate, just can't remember how long. It seems very odd though - makes me wonder if it's truly loading from the Hopper.
FWIW, I don't think the deal really has anything to do with the app itself. I've noticed that if you uninstall & reinstall that any "Favorites" you have selected are retained meaning, they are stored on the Dish servers. This being the case I'm betting that the subscriber channels are as well and it's here that new channels are slow to be propagated. This explains why the actual receiver guide isn't mirrored on the app. I also checked online today and the same behavior exists logging in via my Desktop PC - the last 2 channels added to my subscription have not been added yet.
Watch Disney Jr now available?
3 Ghz Coax Required
