dish 510 dvr showing low signal | SatelliteGuys.US
all4jo
398
12
Haiti and lexington ky
Hey guys, so i have a 722 and 510 . when i try to watch disney channel on the 510 i get no signal errors, and when i check signal on transponder 6 on the 722 i get 40-45 but when i check it on the 510 i get 7-10.
i would like to also say that i using a dpp44 switch. and where i have the 510 i used to have a 622 that just started having reboot problems. and it used to get good signal on that transponder.
I'd try another port on the DPP44 (since you would appear to have two unused ports).
You could also try plugging in the 510 where the ViP722 is as a test.
The key is to establish whether the problem is with the receiver or something else.
What are the signal strengths on transponders 14, 15, 16 and 21 on both 119 and 110? You may need to repeak your dish or even replace some cable. A signal strength of 40-45 on the 722 is also low and should be up in the 70-80 range on transponder 6. Knowing the strengths of the other transponders and satellites can help to give a larger picture of what is going on.
vip722k remote issues
Will Ooma work with DISH Network?
