dish 500 | SatelliteGuys.US
dish 500
clydesam
73
Currently have a dish 500 seeing 119 and 110. A sec swing dish 61.5. Using a 622. Since today they launched the new hd from 72.7. Could you just move the dish 500 pointed at 119 and 110.To the 72.7 and 77 location?
You can use the 500 to get 72.7, but not also 77 because of the 9 degree spacing on the 500. Theoretically, you could use the 500 for 61/72, and the wing for 77. The signals wouldn't be so strong on the 500, but should work.
You can check the "list" near the top of the page to check, cause there might not be any nationals on 77; if not, just use the 500 for 72.7, as long as your locals aren't on 77.
Thanks for the info but cant do. I just looked out my patio where the dishes are. The one at 61.5 I could move but then I would lose my local hd and lot of the other hd channels. The other dish that I receive 119/110 is next to the brick wall and no way to move in that direction of 72.7
RTV - RTN Network
HD RSNs on Dish
