Dish 500 with DVR625?? Can that Cause PQ Problems?? | SatelliteGuys.US
RocketFoot
168
Southwestern PA
Ever since I upgraded from 2-301's to a 625, my locals PQ has been poor. I have been thinking that maybe some of has to do with the fact that the installer upgraded my older Dish 500 antenna and never installed a new on. Do you tink this is an issue and/or what is available to replace the 500 Antenna?
The poor PQ seems to be digital compression problems...pixelation and poor transitions on dark back grounds. It is driving me nuts!
The Dish 500 should work fine with the 625.
Are you getting a good strong signal? If not it may be an aiming issue. Have the installer re-peak the signal.
Another possibility is a flakey 625 or a 625 in need or rebooting. With all Dish DVRs you are not actually watching the stream as it comes from the satellite, but you are watching a replay of it as it is recorded on the hard drive. If the DVR is not recording properly or playing back properly you loose detail. Have you done a hard reboot - unplug for several minutes and restart?
Either cause could exibit these symptoms. It is akin to recording at low bitrate on a TiVo (blacks flatten out blockiness and pixelation with motion of the entire screen.
Pulling the Pin..................
625 Upgrade & keep single cable to set
