Dish 500 To Pick up 129 | SatelliteGuys.US
Jpar
30
Eastern Virginia
Hey fellows,
How do you hook up the 2nd Dish 500 to tie in to pick up Satellite 129.
One dish to point at 119 and 110 2nd dish to point at 129.
Do you use a SW21 to tie these togather?
Be using a 311 receiver. What type of Feed Horns..
Thank you,
Jpar
a DP dual on the 2nd dish. From there, you have options. A DPP twin on the main dish will have an input for that dual. OTOH, if you have a DP Twin, you need a DP21.....
Now, if you are using legacy lnbs, you would need a legacy dual, legacy twin, and a SW21.
Dish 500 to Receive 129
Have LB now
We are hoping in the near future?? that dish will put 129 on 110, but for
now I would like to get our Local Networks.
I got a few 500 around and some LB's
Got a few Sw21's too..
Thanks for your input on this..
It good you guys are here to help.
Thanks!
Jpar
Dish 500- 129
Hey!
could you explain a bit more on how to wire up the legacy LB's to make this work..
Thanks guys for your help!
Jpar
Dish 500 for 129
Chad, I will go for the Legency LB. I think that is what is on the Dish 500 now that is being used. Need to wire from here to the other Dish 500 to point at 129
I have a variety of LB's available.
Jpar
Dish 500 sat 129
Chad, You sure gave me the complete answer on my question for the 2nd dish hook up!!
Like you said a picture is worth a Thousand words.
And it is.
Thank you for explaining this hook up for me..
Thank you,
Happy Easter!
Jpar
942 question
D0's & Dont's of eBay Selling
