dish 500 for 119 and 129 | SatelliteGuys.US
the mack
1,479
483
HOCKEYTOWN
at my cottage install I have HUGE LOS issues and currently use 2 old direct dishes pointed at 110&119 and a sw21. the dishes are about 100' apart, and work fine.
I now will be talking my new 722k there when I visit now(my only receiver) so I have the new problem in that I will need 2 inputs for the receiver.
I want to switch to dpp stuff for the cabling advantages and believe I can get 129 where my 119 dish is now, so I would like to use a dish 500 for 119 and 129 and a wing dish for 110.
I have a dpp plus twin for the 500 and a dp dual for the wing dish and assume there will be no probs with the switching, I just need to know what skew, az and elevation adjustments to make.
the zip code is 48430
It is probably a easy tweak, but some professional insight would be great.
Eastern Arc is out of the question.
TIA
dish 500h will get 119 and 129, i believe its a dpp dish and should have the input on the lnb for your other single feed from 110. using a dish 500 will get you there, but signal wont be as good. i dont have the angles at the moment, i might be able to get back with them but it will be monday
I am assuming the skew would stay the same and the elevation would be lowered 3-4 degrees and the azimuth would be about 10 degrees to the right form behind the dish?
close
the degrees is probably right the skew most likely will need a bit of a tweak. Check for the LNB input on the dpp 500 LNB and then you can use a single line to the 722K and a separator to split it at the K's inputs.
2 dish vs 1 dish
Lost all signals. Please advise.
