dish 500 - 119 ok but no 110 | SatelliteGuys.US
afixer
15
so i have a dish 500 with a dual lnb 119 and 110 and im locked in on 119 but the lnb won find 110 no matter how hard i search. swapped wires and still nothing. could the switch in the lnb be bad? or just the 110 lnb side
i will assume you have a twin, not a dual lnb. but yes, they can go bad like that. much more likely though, is that your dish is mis-alligned.
replaced the lnb and its fine now. the alignment was fine had it hooked up to my super buddy 21 and it was not getting 110
thanks for the input
Both 622's in infinite reboot cycle: What could be the casue?
OTA Recordings take up 2x - 3x space on disk
