Dish 411 won't stay on.... | SatelliteGuys.US
cruzmisl
114
Hi All,
I have a dish 411 that I set the inactivity stand by to disabled but the unit still shuts off after several hours of inactivity. This wouldn't be an issue but my Tivo doesn't record when it's turned off :(
Any advice appreciated.
Thanks,
J.
Hmm, never thought of the nightly dl. Can I turn that off too and do it manually instead or is that something that needs to happen? I'd be OK with it if it would turn back on after ;)
It's a subset of recording. It turns the unit on and turns it to a particular channel. Press DVR twice then navigate to manual timer. One option on manual timer is autotune.
Dish Bird Droppings!
Question about Logo burn in on new HD channels
