Dish 322 Installation | SatelliteGuys.US
bob4adodge
6
I have a dish 322 reciever, and a PRO PLUS LNB ordered. What else will I need to install the reciever in a RV so I can watch two TVs. I am presently using a dish 500 and two recievers. I want to do away with the two cables and two recievers in the RV.
You can use a single wire run to the 322 with a Dish Pro Plus lnb if you use the seperator. If you use diplexers your can backfeed tv2 through the same cable. You will need a cable to the second tv though and it must tie into the sat line.
A Present from All American Direct
Dish replace a 721
