Dish 222 L3.02 Software Release Notes | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,759
29,601
Newington, CT
L3.02 for the ViP 222 was released to support the automatic mapdown feature for High Def Regional Sports Networks. This feature allows preferential tuning to the High Def version of RSN games when available.
Thanks. I got this update and was wondering what it was suppose to fix, since there was no obvious changes. There are some problems with the 222, one of which it seems to loose the sat signal a lot (while other receivers on same system are fine) and has to be rebooted to correct the problem. Sometimes happens daily.
Any word on when Dish will be upgrading the software on the 222 for ethernet access? I'm hoping to avoid paying any additional $5 fees.
This happens to my 222 everyday almost, but it will never go 2 days without a reboot, this is the worst receiver I have ever had, tech support replaced the original but the replacement has the same exact problems
Bob
Bob
I'm on #3. The only answer I get is that they know there is a problem and are working on it. I think I've had mine for about 6 months or so. There are a couple of other issues too, but this is the most irritating.
texas locals
Signal strength questions 500 dish 211 receiver
