Dish 211/411 L3.45 Release Notes | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,758
29,593
Newington, CT
Here is the software released notes from DBStalk. I do appologize I forgot to post them earlier. :)
http://www.dbstalk.com/showthread.php?t=81020
NEW FEATURES:
HD/SD Channel Mapping feature with New HD logo
Enhanced iTV Triggers
Sat 148 all transponders now available in point-dish menu
STB 'Send Status' / Modem Upload feature
BUGS FIXED:
Menus: Favorite List now changes only with double hit of guide key
Menus: Cannot tune to the PPV free preview during the free preview period unless we are already tuned to that channel
Menus: EPG date is over-running the provided space
Menus: Revise the phone system setup screen
Menus: Fix for No Caller ID popup but Caller ID info in history
Menus: Allow the guide key to work when in rain fade state, popup 002
Menus: Info screen scrolling works properly, need to use on a PPV channel
Checkswitch: Fix for Checkswitch run on straight 119 feeds shows reception error
Checkswitch: Checkswitch enhancements with a DPP1K.2 or a DPPTwin and an open port
Text change: Correct Popup 030 to display "030" for error number instead of "028"
Text change: Favorites list help text missing the word "clear"
Text change: SW Copyright text is now "2007"
Text change: Add Tribune Media copyright text
Fix for cascading DP44 DP21 switches (5-Sat. support)
Open TV Weather app hangs on exit
Satellite 118.7 fix for finding all transponders
Question about DD 5.1 on Voom/HD locals
Dish Pro Plus & 322 & 3900
