Dish 1000 with DPP44 switch | SatelliteGuys.US
mlb
1,027
Kettering, Ohio
What coax connections on the DPP Twin LNBF should I be using? Currently I'm able to see the 119 and 129 satellites (on its own separate LNFB), but not on the 110. Apparently I have something wired up wrong in the dish as it runs to my DPP44 switch.
Already done. The issue is that I can't see the 110 satellite. On the twin LNBF I have ports labeled 1 and 2 running to the DPP44. Is that correct or should I have something else?
Found a diagram on the tech portal... I definitely have it right. I guess I'll check the connections and fix later.
Issues upgrading on your own?
DVR rebates
